查看: 9169|回复: 1
[MITfinance lecture经济学讲座][RM][145M][4.6K]
yzh1680 该用户已被删除
发表于 2005-12-27 21:46:06 | 显示全部楼层 |阅读模式
附件  rtsp://a847.v128002.c12800.g.vr. ... rot-27nov01-220k.rm" h2 _: e( d: X8 V! P, ~
, Y& Q5 U+ p9 z) u这只是链接,下载完需在线播放: s* _9 m) ]: v7 P( D6 \* p
$ K; G+ t% o* r) _3 }这是我第一次连接,不知可不可以!
+ m- @- g: ]0 `
% \: z) O5 t$ r' a8 u% \4 V
请注意发贴格式,这次我给你改过来了,不次要注意啊
' a' I% X0 `( I1 S( q- n$ s[ 本帖最后由 lr6600 于 2005-12-28 13:09 编辑 ]
发表于 2005-12-28 13:10:54 | 显示全部楼层
Wed Dec 28 13:08:21 2005 正在连接 a847.v128002.c12800.g.vr.akamaistream.net:554
( g0 r/ I. E9 _6 }! J  M* z) XWed Dec 28 13:08:21 2005 正在连接 a847.v128002.c12800.g.vr.akamaistream.net [IP=209.170.95.78:554]$ [4 W1 e9 f) h2 M+ o( g+ U) @
Wed Dec 28 13:08:22 2005 已连接." R' _; C2 S$ ^! J
Wed Dec 28 13:08:22 2005 OPTIONS rtsp://a847.v128002.c12800.g.vr.akamaistream.net:554 RTSP/1.0
  R: T! j' A9 e2 k5 KWed Dec 28 13:08:22 2005 CSeq: 1
+ J( O. L! E0 _( r' c0 {Wed Dec 28 13:08:22 2005 User-Agent: RealMedia Player Version 6.0.9.1235 (linux-2.0-libc6-i386-gcc2.95)
0 G  v" _) f* x4 C; [9 YWed Dec 28 13:08:22 2005 ClientChallenge: 9e26d33f2984236010ef6253fb1887f7
0 a! `9 I5 A) d/ |" ^1 ^- [Wed Dec 28 13:08:22 2005 PlayerStarttime: [28/03/2003:22:50:23 00:00]
1 B! f8 t: |' W) pWed Dec 28 13:08:22 2005 CompanyID: KnKV4M4I/B2FjJ1TToLycw==
+ t. `( S& @, w/ \Wed Dec 28 13:08:22 2005 GUID: 00000000-0000-0000-0000-0000000000004 n2 P; ^: B4 ]7 Z( z5 _
Wed Dec 28 13:08:22 2005 RegionData: 0, C5 P4 y1 K' l3 D- ^2 J2 H& I
Wed Dec 28 13:08:22 2005 ClientID: Linux_2.4_6.0.9.1235_play32_RN01_EN_586: E( K: G7 n# D; a$ E
Wed Dec 28 13:08:22 2005 Pragma: initiate-session1 z* L$ z) B  i5 c; h/ O$ i" _
Wed Dec 28 13:08:23 2005 RTSP/1.0 200 OK9 ^( k$ q! U0 M( e% d: u0 ?
Wed Dec 28 13:08:23 2005 CSeq: 1
: e1 n/ g3 t+ w  s* j6 R# z! q( nWed Dec 28 13:08:23 2005 Date: Wed, 28 Dec 2005 05:08:20 GMT8 N% K; l8 o5 E
Wed Dec 28 13:08:23 2005 Session: 949339337-18 p8 W9 E/ w+ j, l& z5 C- m
Wed Dec 28 13:08:23 2005 Server: Helix Server Version 9.0.5.1159 (linux-2.2-libc6-i586-server) (RealServer compatible)
: }) Y( _6 B" c( q. \Wed Dec 28 13:08:23 2005 Public: OPTIONS, DESCRIBE, ANNOUNCE, PLAY, SETUP, GET_PARAMETER, SET_PARAMETER, TEARDOWN
3 B! k* @2 j! y( Z! FWed Dec 28 13:08:23 2005 RealChallenge1: 1a7a2c701f9dc8841c57a76081450ef16 ^) Y5 _! y7 z6 q8 N& V$ O; C+ x
Wed Dec 28 13:08:23 2005 StatsMask: 3& \# ~6 U+ I$ N% O4 Y
Wed Dec 28 13:08:23 2005 DESCRIBE rtsp://a847.v128002.c12800.g.vr. ... rot-27nov01-220k.rm RTSP/1.0
% I$ i( U2 V' k( LWed Dec 28 13:08:23 2005 CSeq: 22 f7 F+ k3 l% F, X+ K
Wed Dec 28 13:08:23 2005 Authorization: Basic RVB1YlNob3dEb3duOjRmYTNncjV0OA==
% J; K% w/ O8 @6 @, E1 R, l- L( tWed Dec 28 13:08:23 2005 Accept: application/sdp9 v  k2 V5 j- d3 H$ p" _4 h4 w& }
3 V) J( X7 F5 J+ q2 r( ^1 ~$ {; vWed Dec 28 13:08:23 2005 Bandwidth: 10485800
/ R7 R4 Y+ T0 {' P1 SWed Dec 28 13:08:23 2005 SupportsMaximumASMBandwidth: 1
' u' e( H8 c" U& ^. C- V/ {7 rWed Dec 28 13:08:23 2005 GUID: 00000000-0000-0000-0000-000000000000, }9 w3 `+ e: D: [
Wed Dec 28 13:08:23 2005 Require: com.real.retain-entity-for-setup! F. [6 I" P  `/ o' _- n- e
- N+ i$ g+ g2 ?: xWed Dec 28 13:08:23 2005 CSeq: 22 _- u: n$ O7 u; _( S( ?" l3 s4 X6 s
* f1 d0 D9 U% W7 p& f$ IWed Dec 28 13:08:23 2005 Set-Cookie: cbid=dkcgcmgihggfildmeolomplqpojrktlufkjjkidlegnkdlpllnorhphqerpskqpudkdgphel;path=/;expires=Thu,31-Dec-2037 23:59:59 GMT
% _, [$ N5 Y: ?# U+ f% ]Wed Dec 28 13:08:23 2005 Content-base: rtsp://a847.v128002.c12800.g.vr. ... ot-27nov01-220k.rm/- V1 M0 T) f" h: S! p
Wed Dec 28 13:08:23 2005 ETag: 949339337-1
8 m* f) m3 ]5 g& U: AWed Dec 28 13:08:23 2005 Session: 949339337-18 Z( |7 j& c) [& @( ^7 n: h& J
Wed Dec 28 13:08:23 2005 Content-type: application/sdp
; o/ U. A* y% `; Q/ c3 [( P. SWed Dec 28 13:08:23 2005 Content-length: 1933
7 r% j# }3 _8 p# L8 C) {, P4 xWed Dec 28 13:08:23 2005 v=0. L& p0 D2 x3 H
Wed Dec 28 13:08:23 2005 o=- 891433 891433 IN IP4
2 W4 h! {2 r8 u) k/ \! A! OWed Dec 28 13:08:23 2005 s=<No title>
* i) a# D2 _: @. YWed Dec 28 13:08:23 2005 i=<No author> <No copyright>& H; y3 N6 }) A0 V! r2 Q
Wed Dec 28 13:08:23 2005 t=0 0
- }5 A# Y# e% h, C  T; g7 ?Wed Dec 28 13:08:23 2005 a=SdpplinVersion:1610645485
' I1 _4 k  }0 @6 uWed Dec 28 13:08:23 2005 a=Flags:integer;2
+ ?0 d2 j$ z- u9 S5 s$ y5 fWed Dec 28 13:08:23 2005 a=IsRealDataType:integer;1
! o; T* m# u. z3 n- e) i3 fWed Dec 28 13:08:23 2005 a=StreamCount:integer;2
+ M5 }7 T) L* ]9 n, q! l: zWed Dec 28 13:08:23 2005 a=Keywords:string;""
7 J/ ^$ J) i9 S' k9 gWed Dec 28 13:08:23 2005 a=Abstract:string;""
# s  P, [, h/ A" C1 z! Z6 @/ SWed Dec 28 13:08:23 2005 a=range:npt=0-0. A$ N6 u6 y6 O( ?/ I
Wed Dec 28 13:08:23 2005 m=audio 0 RTP/AVP 1012 d6 t9 ~8 M. _0 r3 y  J8 w+ }0 G
Wed Dec 28 13:08:23 2005 b=AS:326 [) R; D$ i5 C$ _8 _2 m
Wed Dec 28 13:08:23 2005 a=control:streamid=0
3 W( ]/ \3 G) m+ |& D; sWed Dec 28 13:08:23 2005 a=range:npt=0-4855.012000
6 ^% e1 x& b( Z" S9 \0 \7 DWed Dec 28 13:08:23 2005 a=length:npt=4855.012000& S! k) o" t1 B' T1 s: J& B
Wed Dec 28 13:08:23 2005 a=rtpmap:101 x-pn-realaudio/1000- Q" }( h+ D: ~7 b0 a6 u8 o
Wed Dec 28 13:08:23 2005 a=mimetype:string;"audio/x-pn-realaudio"
6 H) h. K/ |2 b& H1 S8 {Wed Dec 28 13:08:23 2005 a=AvgBitRate:integer;32041
0 B, Z7 F( ^3 F5 S9 f! oWed Dec 28 13:08:23 2005 a=EndOneRuleEndAll:integer;1
, @" I# G. f; O: Y* @Wed Dec 28 13:08:23 2005 a=AvgPacketSize:integer;5584 F5 i" ?* F1 w5 g' q3 U* x
Wed Dec 28 13:08:23 2005 a=EndTime:integer;4852889
0 a! h6 I8 P' I( W4 F. D9 F! [Wed Dec 28 13:08:23 2005 a=ActualPreroll:integer;2229
- {% E  [7 w5 y# `' }  T2 C8 L6 eWed Dec 28 13:08:23 2005 a=Preroll:integer;4458
$ B5 _7 C% m2 y. `Wed Dec 28 13:08:23 2005 a=MaxPacketSize:integer;558" H+ Z5 a& }9 U' ^3 }$ v
Wed Dec 28 13:08:23 2005 a=MaxBitRate:integer;32041
1 ^. z+ B; x; j3 S! e+ z+ Q* HWed Dec 28 13:08:23 2005 a=RMFF 1.0 Flags:buffer;"AAIAAgAA", y2 {5 S. i( ~5 t
Wed Dec 28 13:08:23 2005 a=OpaqueData:buffer;"LnJh/QAFAAAucmE1ZgVhxwAFAAAARgAHAAACLgEotcAAA6q3AAAAAAAQAi4AXQAAAABWIgAAViIAAAAQAAFnZW5yY29vawECAAAAAAAIAQAAAgIAABg="
! U* _# ]) F+ ]# S, i+ S6 v/ kWed Dec 28 13:08:23 2005 a=StreamName:string;"Audio Stream"- g8 X0 n0 z1 C1 x3 G# w
Wed Dec 28 13:08:23 2005 a=intrinsicDurationType:string;"intrinsicDurationContinuous"
) X/ y3 ~" r+ v, C% sWed Dec 28 13:08:23 2005 a=ASMRuleBook:string;"priority=5,averagebandwidth=32041,PNMKeyFrameRule=T;priority=5,averagebandwidth=0,PNMNonKeyFrameRule=T,OnDepend=\"0\",OffDepend=\"0\";"$ c' {% {8 \+ y- p4 {! S$ g# u
Wed Dec 28 13:08:23 2005 m=video 0 RTP/AVP 101
9 u: D$ L# v/ u1 O% g: [Wed Dec 28 13:08:23 2005 b=AS:188
3 p/ r* v9 Q4 v" dWed Dec 28 13:08:23 2005 a=control:streamid=13 x3 y" I5 y( [4 j: a
Wed Dec 28 13:08:23 2005 a=range:npt=0-4852.452000  R# v# w/ \, K- R* l8 H! p
Wed Dec 28 13:08:23 2005 a=length:npt=4852.452000# D4 m! ?6 q. O" _7 a
Wed Dec 28 13:08:23 2005 a=rtpmap:101 x-pn-realvideo/10002 }; `" D* P9 t. U+ a
Wed Dec 28 13:08:23 2005 a=mimetype:string;"video/x-pn-realvideo"; d( ]$ o' r, ^2 s' w  H
Wed Dec 28 13:08:23 2005 a=AvgBitRate:integer;187958" ~' @5 c- B* @  y
8 L2 v3 q  _, K1 U( gWed Dec 28 13:08:23 2005 a=AvgPacketSize:integer;872* Z/ p/ P: r$ y/ U5 k
Wed Dec 28 13:08:23 2005 a=Preroll:integer;4470
0 U9 M" }' m/ s- O" ^Wed Dec 28 13:08:23 2005 a=MaxPacketSize:integer;1011) ?6 m( x. T0 m
Wed Dec 28 13:08:23 2005 a=MaxBitRate:integer;187958( F; c# |' c$ H0 ^0 D7 t. g
Wed Dec 28 13:08:23 2005 a=RMFF 1.0 Flags:buffer;"AAMAAgAAAAI="8 q+ `6 l7 L2 a8 q* y9 J& i' ]
Wed Dec 28 13:08:23 2005 a=OpaqueData:buffer;"AAAAKFZJRE9SVjMwAUAA8AAMAAAAAAAKAAABC5AwMCAgAjwsKCBQPA=="$ b1 \" v  f) ]( n
Wed Dec 28 13:08:23 2005 a=StreamName:string;"Video Stream"
1 u; f0 j, ]9 P8 h8 t* Y6 iWed Dec 28 13:08:23 2005 a=intrinsicDurationType:string;"intrinsicDurationContinuous"% Q) U. E' |! [* j1 m- H8 C$ ?: y
Wed Dec 28 13:08:23 2005 a=ASMRuleBook:string;"#($Bandwidth >= 187958),priority=9,averagebandwidth=187958,PNMKeyFrameRule=T;#($Bandwidth >= 187958),OnDepend=\"0\",priority=5,averagebandwidth=0,PNMNonKeyFrameRule=T;#($Bandwidth < 187958),priority=9,timestampdelivery=T,DropByN=T,PNMThinningRule=T;"
8 K3 n$ \. W0 p1 ]Wed Dec 28 13:08:23 2005 开始接受数据!
GMT+8, 2025-4-11 07:08
Powered by Discuz!
© 2001-2025 eimhe.com.
