查看: 22617|回复: 13
[庞中华硬笔书法教程][10讲][RM][40K]
发表于 2005-12-12 22:53:59 | 显示全部楼层 |阅读模式
rtsp://61.175.216.238:554/dy/艺教天地/庞中华硬笔书法教程/01.rm6 e3 z0 ?' H2 z1 k* y: B( r: D
中间加
" y3 [5 C. w  p) m3 a1 a8 G0 X* d7 l2 H! \
rtsp://61.175.216.238:554/dy/艺教天地/庞中华硬笔书法教程/10.rm  e/ p- N* K/ [
. r9 Z! }  }- G
[ 本帖最后由 lr6600 于 2005-12-13 12:40 编辑 ]
发表于 2005-12-13 12:39:18 | 显示全部楼层
Tue Dec 13 12:40:42 2005 正在连接 61.175.216.238 [IP=61.175.216.238:554]- R# J7 l  N" ]
Tue Dec 13 12:40:42 2005 已连接.
: N- k8 U% {2 J6 b6 K5 vTue Dec 13 12:40:42 2005 OPTIONS rtsp://61.175.216.238:554 RTSP/1.0
1 T4 q7 y+ |5 ~; `3 k) J7 e  {Tue Dec 13 12:40:42 2005 CSeq: 1
9 u2 k1 ?3 @1 x" h# R& O' sTue Dec 13 12:40:42 2005 User-Agent: RealMedia Player Version 6.0.9.1235 (linux-2.0-libc6-i386-gcc2.95)# R& c' q, x! i4 h* Q. |( W
Tue Dec 13 12:40:42 2005 ClientChallenge: 9e26d33f2984236010ef6253fb1887f7
  |, n8 R7 H: K9 p8 Z; F2 @Tue Dec 13 12:40:42 2005 PlayerStarttime: [28/03/2003:22:50:23 00:00]3 S, n% c  S0 Z. _4 k" o# O4 W
Tue Dec 13 12:40:42 2005 CompanyID: KnKV4M4I/B2FjJ1TToLycw==
0 H" s+ x6 x6 ?# [; K. j# ]Tue Dec 13 12:40:42 2005 GUID: 00000000-0000-0000-0000-000000000000* F# W& g7 H; Q9 G) _, y: [# I  v' C5 {
Tue Dec 13 12:40:42 2005 RegionData: 0
3 e, v0 k6 I* RTue Dec 13 12:40:42 2005 ClientID: Linux_2.4_6.0.9.1235_play32_RN01_EN_586
1 E$ S9 W2 G% i( O6 bTue Dec 13 12:40:42 2005 Pragma: initiate-session( I: z! T, T9 u' k- E  |! Z/ Y
Tue Dec 13 12:40:42 2005 RTSP/1.0 200 OK
/ P/ r: b1 ]/ F) L! e9 V, _Tue Dec 13 12:40:42 2005 CSeq: 1
& V* \5 {, C+ p  c5 |! \Tue Dec 13 12:40:42 2005 Date: Tue, 13 Dec 2005 04:40:47 GMT% t$ A! \/ y' n  p
Tue Dec 13 12:40:42 2005 Session: 249307-1
& G2 [& A9 ]& [# B& n7 VTue Dec 13 12:40:42 2005 Server: Helix Server Version 9.0.3.916 (win32) (RealServer compatible)
# l' i& W" z4 c0 U- r8 [4 D# p! GTue Dec 13 12:40:42 2005 Public: OPTIONS, DESCRIBE, ANNOUNCE, PLAY, SETUP, GET_PARAMETER, SET_PARAMETER, TEARDOWN
! i& H. D: [4 x8 s0 C& BTue Dec 13 12:40:42 2005 RealChallenge1: 42e4f966999e9d971dfa81c4f5ca45668 Z  W, M) `( I8 a! L
Tue Dec 13 12:40:42 2005 StatsMask: 3- n$ C" D  F$ h4 b0 T
Tue Dec 13 12:40:42 2005 DESCRIBE rtsp://61.175.216.238/dy/%D2%D5% ... 8%BD%CC%B3%CC/10.rm RTSP/1.0
1 n1 w4 l" @0 t# S3 l+ T: z$ xTue Dec 13 12:40:42 2005 CSeq: 2+ ^& ], A. C5 W7 m, f  U
Tue Dec 13 12:40:42 2005 Authorization: Basic RVB1YlNob3dEb3duOjRmYTNncjV0OA==
; ?5 S( w* y" h, v3 _4 `- vTue Dec 13 12:40:42 2005 Accept: application/sdp; ^& Q( F% y( a$ r) r0 l( b. T! S
Tue Dec 13 12:40:42 2005 Session: 249307-18 q9 C1 C& @' G$ J1 O
Tue Dec 13 12:40:42 2005 Bandwidth: 10485800: d' O2 e2 B2 C2 c( @# P8 X8 r) s2 H
Tue Dec 13 12:40:42 2005 SupportsMaximumASMBandwidth: 1# T6 E, j/ i" Q$ r
Tue Dec 13 12:40:42 2005 GUID: 00000000-0000-0000-0000-000000000000* v9 ~+ k+ g+ e2 F4 I
Tue Dec 13 12:40:42 2005 Require: com.real.retain-entity-for-setup# H9 d$ L0 `* O4 P' `
. C! C0 X5 s$ K# nTue Dec 13 12:40:42 2005 CSeq: 29 O# A3 b1 s, Y" P& B/ h2 O+ V
$ y5 G" K2 u8 ^+ l2 v$ TTue Dec 13 12:40:42 2005 Set-Cookie: cbid=dffgehhlfjdffigheokolurtlrjrptppqfrgkipiijnkfiplnskrnpptnrpsntmuifejdhdl;path=/;expires=Thu,31-Dec-2037 23:59:59 GMT
+ B( r1 b9 }% [2 |Tue Dec 13 12:40:42 2005 vsrc: http://61.175.216.238:8080/views ... gtAqlrgpvst3cx854E65 K- G% C3 N& T* \) {4 _# Y7 }
Tue Dec 13 12:40:42 2005 Last-Modified: Sat, 04 Jun 2005 13:01:46 GMT$ j4 ?  p) }! V5 d3 t/ c
Tue Dec 13 12:40:42 2005 Content-base: rtsp://61.175.216.238/dy/%D2%D5% ... %BD%CC%B3%CC/10.rm/
, P7 o6 f5 S* B# {: L4 fTue Dec 13 12:40:42 2005 ETag: 249307-16 P6 H' T- h4 i9 X! k
! B$ W9 o5 J+ M( m$ N) p5 n6 V4 |Tue Dec 13 12:40:42 2005 Content-type: application/sdp9 T+ J# A' }) V2 X% j: \6 U
Tue Dec 13 12:40:42 2005 Content-length: 2165
$ o" D5 p4 f8 D- L3 zTue Dec 13 12:40:42 2005 v=0
& h& b+ j3 b( ?4 H# C2 VTue Dec 13 12:40:42 2005 o=- 1117890106 1117890106 IN IP4 61.175.216.2389 a: R6 {" _* w8 A$ w2 k1 J. r
Tue Dec 13 12:40:42 2005 s=AVSEQ049 L6 z0 a3 f8 Z
Tue Dec 13 12:40:42 2005 i=Kenx Kenxsoft 2002
0 h3 C: s! N4 yTue Dec 13 12:40:42 2005 t=0 0* {. Q: J7 L8 A9 c$ D+ T
Tue Dec 13 12:40:42 2005 a=SdpplinVersion:1610645242
; N6 C/ L8 M! G1 `Tue Dec 13 12:40:42 2005 a=Flags:integer;11% F1 W. y# f) h- e9 y2 Y; c1 ~* q
Tue Dec 13 12:40:42 2005 a=IsRealDataType:integer;1+ h  @5 f- F0 A
Tue Dec 13 12:40:42 2005 a=StreamCount:integer;2
6 g$ C9 I7 Y# y& _! ]5 jTue Dec 13 12:40:42 2005 a=Author:buffer;"S2VueAA="
4 w. N" h0 {8 ?3 p. E# z5 h1 KTue Dec 13 12:40:42 2005 a=Copyright:buffer;"S2VueHNvZnQgMjAwMgA="
, t3 @- n$ d, i/ [8 X4 nTue Dec 13 12:40:42 2005 a=Title:buffer;"QVZTRVEwNAA="8 p; m* B% @" U
Tue Dec 13 12:40:42 2005 a=Abstract:string;"文件是由创前工作室开发的RA
+ X6 t! K( d) dTue Dec 13 12:40:42 2005 RM压缩器 , Real2002压缩生成
3 {0 [1 D, `; L# v# q) \& \( N6 _Tue Dec 13 12:40:42 2005 http://cqkenx.myetang.com"
4 p" p4 v$ i  _0 o& o5 u8 K! TTue Dec 13 12:40:42 2005 a=Keywords:string;"网络多媒体文件", t9 v: A) o0 F
Tue Dec 13 12:40:42 2005 a=range:npt=0-08 l+ z9 t$ Y0 z. L% L
Tue Dec 13 12:40:42 2005 m=audio 0 RTP/AVP 101
$ p! r1 E# z4 T% R- h+ e  ^Tue Dec 13 12:40:42 2005 b=AS:66
+ f5 x7 O: j0 P9 `; m/ N+ v2 FTue Dec 13 12:40:42 2005 a=control:streamid=0. ^$ v' N% U# k7 i1 W5 ?
Tue Dec 13 12:40:42 2005 a=range:npt=0-847.062000
8 R) `- t" }- }" ]; vTue Dec 13 12:40:42 2005 a=length:npt=847.062000
9 V3 g, S1 p3 s. W5 C& a" j% cTue Dec 13 12:40:42 2005 a=rtpmap:101 x-pn-realaudio/10006 L% x% @6 }+ V2 W" m% @" ^- v- C7 l
Tue Dec 13 12:40:42 2005 a=mimetype:string;"audio/x-pn-realaudio"" e2 Z/ Z' P1 d$ Y5 a0 [0 P( P
Tue Dec 13 12:40:42 2005 a=ActualPreroll:integer;1857/ e: r/ h: v4 V
Tue Dec 13 12:40:42 2005 a=AvgBitRate:integer;66150
/ l! O( N# @5 TTue Dec 13 12:40:42 2005 a=AvgPacketSize:integer;768
- n1 i8 U9 J; h; W7 s" p2 f" @* zTue Dec 13 12:40:42 2005 a=EndOneRuleEndAll:integer;1
# G0 @( A( U4 ~Tue Dec 13 12:40:42 2005 a=EndTime:integer;846079
4 k" a0 y& {! s/ T7 L# sTue Dec 13 12:40:42 2005 a=MaxBitRate:integer;66150
8 k  D5 c! s7 Q; q' [8 S* t! VTue Dec 13 12:40:42 2005 a=MaxPacketSize:integer;7687 E6 o' ~5 D' I; n
Tue Dec 13 12:40:42 2005 a=Preroll:integer;3714+ z( z8 g5 |: q4 d  a: D% A7 a1 _
Tue Dec 13 12:40:42 2005 a=OpaqueData:buffer;"LnJh/QAFAAAucmE1Ak1hxwAFAAAASAAAAAADAABq4AAAB5H95knYPAAUAwAAwAAAAACsRAAArEQAAAAQAAJnZW5yYXRyYwEHAAAAAAAKAAAABAgACI4AEg=="
2 r" O) p% x% e$ p- QTue Dec 13 12:40:42 2005 a=RMFF 1.0 Flags:buffer;"AAIAAgAA"
7 r# K0 a/ N; f( \9 ~6 s- Y7 I( ETue Dec 13 12:40:42 2005 a=ASMRuleBook:string;"priority=5,averagebandwidth=66150,PNMKeyFrameRule=T;priority=5,averagebandwidth=0,PNMNonKeyFrameRule=T,OnDepend=\"0\",OffDepend=\"0\";"
- C" i8 W- O+ n  x) q! v3 X2 mTue Dec 13 12:40:42 2005 a=intrinsicDurationType:string;"intrinsicDurationContinuous"1 h+ r6 }9 n! ?" R$ _, X+ h
Tue Dec 13 12:40:42 2005 a=StreamName:string;"Audio Stream"
+ C: }5 L' l# D6 x9 R4 qTue Dec 13 12:40:42 2005 m=video 0 RTP/AVP 1011 |6 L( q2 U" W8 H' V
Tue Dec 13 12:40:42 2005 b=AS:334( w% Z# v: z. y4 C" |5 Q% v
Tue Dec 13 12:40:42 2005 a=control:streamid=1
0 q/ \# u$ k! H; p+ eTue Dec 13 12:40:42 2005 a=range:npt=0-846.0860004 f5 s: f$ e8 B/ r, b8 T
Tue Dec 13 12:40:42 2005 a=length:npt=846.086000
" d5 E7 h; H' u7 Z& ^! S/ mTue Dec 13 12:40:42 2005 a=rtpmap:101 x-pn-realvideo/1000% d( H/ n; y' Q  T
Tue Dec 13 12:40:42 2005 a=mimetype:string;"video/x-pn-realvideo"
; ~! p; p' D/ {; VTue Dec 13 12:40:42 2005 a=AvgBitRate:integer;333850
$ K! ^' [& a0 d( b, h6 E0 S4 eTue Dec 13 12:40:42 2005 a=AvgPacketSize:integer;1185$ d( W% ~: r* }. A- S9 o
Tue Dec 13 12:40:42 2005 a=EndOneRuleEndAll:integer;1, B9 l0 y* d4 v7 y" o/ j# f' l
Tue Dec 13 12:40:42 2005 a=EndTime:integer;846079) R# |% N2 W6 S  b' o$ t3 J
Tue Dec 13 12:40:42 2005 a=MaxBitRate:integer;3338508 H. {! h- }+ g+ z# G
Tue Dec 13 12:40:42 2005 a=MaxPacketSize:integer;1409+ V% i; X! [6 k* z% s( y# T
Tue Dec 13 12:40:42 2005 a=Preroll:integer;2527
0 y8 W" J3 \* j3 S# _! U" W, [Tue Dec 13 12:40:42 2005 a=OpaqueData:buffer;"AAAAJlZJRE9SVjMwAWABIAAMAAAAAAAPAAABCpAwMCAgAkA0LCQ="
% v8 C, t' @; B' H! N: O0 YTue Dec 13 12:40:42 2005 a=RMFF 1.0 Flags:buffer;"AAMAAgAAAAI="% T. }& x" U: f# Q* ?1 P7 D; ^
Tue Dec 13 12:40:42 2005 a=ASMRuleBook:string;"#($Bandwidth >= 333850),priority=9,averagebandwidth=333850,PNMKeyFrameRule=T;#($Bandwidth >= 333850),OnDepend=\"0\",priority=5,averagebandwidth=0,PNMNonKeyFrameRule=T;#($Bandwidth < 333850),priority=9,timestampdelivery=T,DropByN=T,PNMThinningRule=T;"# U7 `2 i- N4 t8 c4 k
Tue Dec 13 12:40:42 2005 a=intrinsicDurationType:string;"intrinsicDurationContinuous"/ P" f1 C6 {2 q7 R' `2 ^
Tue Dec 13 12:40:42 2005 a=StreamName:string;"Video Stream"
, G# i5 ?. X; e* x6 X4 _1 nTue Dec 13 12:40:43 2005 开始接受数据!
发表于 2005-12-29 18:06:42 | 显示全部楼层
难道书法也可以在网上教吗
发表于 2006-5-27 20:12:34 | 显示全部楼层
谢谢楼主
发表于 2007-2-25 13:43:11 | 显示全部楼层
下不了啊?
发表于 2007-4-20 02:38:11 | 显示全部楼层
发表于 2007-4-20 14:09:16 | 显示全部楼层
下来看看。好好学习天天向上
发表于 2008-12-16 10:33:27 | 显示全部楼层
资料不错,收下了
发表于 2009-4-23 09:44:47 | 显示全部楼层
完全下不了!
发表于 2009-7-8 09:57:58 | 显示全部楼层
发表于 2009-11-30 08:20:32 | 显示全部楼层
dddddddddddddddddddddddddddddddddddddddddddddddddddddddd
发表于 2009-12-4 13:18:35 | 显示全部楼层
回复 1楼 的帖子
谢谢楼主
GMT+8, 2026-11-20 05:33
