查看: 30533|回复: 15
Yeslab 最新CCIE ISP培训视频含上课所用PPT
发表于 2025-11-24 08:18:32 | 显示全部楼层 |阅读模式
YESLAB 新版全套 CCIE ISP 培训视频 覆盖了ISP 与RS所有知识点,视频与ppt都升级了
1.bgp
1_BGP介绍.mp4
2_BGP的基本配置和概念-上.mp4
2_BGP的基本配置和概念-下.mp4
3_BGP path属性.mp4
4_BGP自动汇总和同步 .mp4
5_BGP排错.mp4
6_Working with a Transit AS.mp4
7_1_Employing AS-Path Filters.mp4
7_2_Employing AS-Path Filters.mp4
8_Filtering with Prefix-Lists.mp4
9_Using Outbound Route Filtering.mp4
10_Applying Route-Maps as BGP Filters.mp4
11_Implementing Changes in BGP Policy.mp4
12_Introducing Route Reflectors.mp4
13_1_BGP选路.mp4
13_2_BGP选路.mp4
13_3_BGP选路.mp4
13_4_BGP选路.mp4
14_1_Introducing Confederations.mp4
14_2_conferations with BGP 13 routes selection.mp4
15_Addressing BGP Communities.mp4
16_Limiting the Number of Prefixes Received from a BGP Neighbor.mp4
17_Implementing BGP Peer Groups.mp4
18_Using BGP Route Dampening.mp4
19_0_Understanding Customer-to-Provider Connectivity Requirements.mp4
19_1_Implementing Customer Connectivity Using Static Routing.mp4
19_2_Connecting a Multihomed Customer to a Single Service Provider.mp4
19_3_Connecting a Multihomed Customer to Multiple Service Providers.mp4
20_Improving BGP Convergence1.mp4
ppt
1_BGP介绍.pdf
2_BGP的基本配置和概念.pdf
3_BGP path属性.pdf
4_BGP自动汇总和同步 .pdf
4_BGP路由处理-del.pdf
5_BGP排错.pdf
6_Working with a Transit AS.pdf
7_Employing AS-Path Filters.pdf
8_Filtering with Prefix-Lists.pdf
9_Using Outbound Route Filtering.pdf
10_Applying Route-Maps as BGP Filters.pdf
11_Implementing Changes in BGP Policy.pdf
12_0_Introducing Route Reflectors.pdf
12_1_Designing Networks with Route Reflectors.pdf
12_2_Configuring and Monitoring Route Reflectors.pdf
13_0_BGP选路.pdf
13_1_Influencing BGP Route Selection with Weights.pdf
13_2_Setting BGP Local Preferences.pdf
13_3_Using AS-Path Prepending.pdf
13_4_Understanding BGP Multi-Exit Discriminators.pdf
14_1_Introducing Confederations.pdf
14_2_Configuring and Monitoring Confederations.pdf
15_Addressing BGP Communities.pdf
16_Limiting the Number of Prefixes Received from a BGP Neighbor.pdf
17_Implementing BGP Peer Groups.pdf
18_Using BGP Route Dampening.pdf
19_0_Understanding Customer-to-Provider Connectivity Requirements.pdf
19_1_Implementing Customer Connectivity Using Static Routing.pdf
19_2__Connecting a Multihomed Customer to a Single Service Provider.pdf
19_3_Connecting a Multihomed Customer to Multiple Service Providers.pdf
20_Improving BGP Convergence1.pdf
2.ipv6
0_ipv6-现状.mp4
1_IPv6 address and header_1.mp4
1_IPv6 address and header_2.mp4
1_IPv6 address and header_3.mp4
2_IPv6 basic config and static route.mp4
3_ICMPv6 and NDP_1.mp4
3_ICMPv6 and NDP_2.mp4
3_ICMPv6 and NDP_3.mp4
4_OSPFv3协议原理和配置-new_1.mp4
4_OSPFv3协议原理和配置-new_2.mp4
4_OSPFv3协议原理和配置-new_3.mp4
5_RIPng协议原理和配置.mp4
6_MP-BGP_for_IPv6和6PE原理和配置-new.mp4
7_IPv6_组播_1.mp4
7_IPv6_组播_2.mp4
7_IPv6_组播_3.mp4
8_IS-ISv6原理和配置.mp4
9_IPv6的共存和过渡策略_1_static tunnel.mp4
9_IPv6的共存和过渡策略_2_auto tunnel.mp4
9_IPv6的共存和过渡策略_3_6to4.mp4
9_IPv6的共存和过渡策略_4_isatap.mp4
9_IPv6的共存和过渡策略_5_6PE.mp4
yeslab ipv6 pdf version
1_IPv6 address and header.pdf
2_IPv6 basic config and static route.pdf
3_ICMPv6 and NDP.pdf
4_OSPFv3协议原理和配置-new.pdf
5_RIPng协议原理和配置.pdf
6_MP-BGP_for_IPv6和6PE原理和配置-new.pdf
7_IPv6_组播.pdf
8_IS-ISv6原理和配置.pdf
9_IPv6的共存和过渡策略.pdf
3.isis
1、Yeslab CCIP-ISIS 基础.mp4
2.1、Yeslab CCIP-ISIS基本概念_1.mp4
2.2、Yeslab CCIP-ISIS基本概念_2.mp4
2.3、Yeslab CCIP-ISIS基本概念_3.mp4
3、Yeslab CCIP-ISIS基本概念续.mp4
4、Yeslab CCIP-ISIS Networks optimization.mp4
5、Yeslab CCIP-ISIS SPF计算.mp4
6、Yeslab CCIP-ISIS timer.mp4
ISIS命令与配置实验手册.pdf
Yeslab_PDF
1、YesLab ISIS基础.pdf
2、YesLab ISIS基本概念.pdf
3、Yeslab ISIS基本概念续 [兼容模式].pdf
4、Yeslab ISISOptimizing IS-IS Networks [兼容模式].pdf
5、YesLab SPF计算 [兼容模式].pdf
6、Yeslab Configuring Integrated IS-IS Convergence Parameters [兼容模式].pdf
4.l2vpn
1_l2vpn-AToM_1.mp4
1_l2vpn-AToM_2-eompls实验.mp4
1_l2vpn-AToM_2-eompls理论.mp4
1_l2vpn-AToM_3-ppp_hdlc_fr.mp4
2_l2vpn-L2TPv3-1理论部分.mp4
2_l2vpn-L2TPv3-2实验EoL2TPV3.mp4
2_l2vpn-L2TPv3-3实验HDLC PPP FR over L2TPV3.mp4
2_l2vpn-L2TPv3-4pmtu.mp4
3_l2vpn-interworking and local switching.mp4
4_l2vpn_vpls-1.mp4
4_l2vpn_vpls-2-HVPLS.mp4
4_l2vpn_vpls-3-redundancy AC.mp4
5.mpls
1_1mpls-1.mp4
1_2_mpls-ldp basic-1.mp4
1_3_mpls-ldp basic-2.mp4
1_4_mpls-ldp feature-LDP和BGP的交互.mp4
2_MPLS报文的转发的几个细节.mp4
3.LDP的收敛.mp4
4.advanced LDP feature.mp4
5_Introducing and Categorizing VPNs.mp4
6_L3 MPLS-VPN原理与应用-MPLS VPN结构_第1和2章.mp4
7_L3 MPLS-VPN原理与应用-PE-CE之间的路由协议_第3章_1-rip.mp4
7_L3 MPLS-VPN原理与应用-PE-CE之间的路由协议_第3章_2-bgp.mp4
7_L3 MPLS-VPN原理与应用-PE-CE之间的路由协议_第3章_3-ospf.mp4
7_L3 MPLS-VPN原理与应用-PE-CE之间的路由协议_第3章_4-eigrp.mp4
8_mpls VPN troubleshooting v2.mp4
9_0_各种复杂VPN介绍.mp4
9_1_mpls-vpn managed CE vpn 实验演示.mp4
9_2_mpls-vpn central service vpn 实验演示.mp4
9_3_mpls-vpn-overlapping vpns 实验演示.mp4
10_L3 MPLS-VPN原理与应用-rj version_第5章-interas vpn_option A.mp4
10_L3 MPLS-VPN原理与应用-rj version_第5章-interas vpn_option B.mp4
10_L3 MPLS-VPN原理与应用-rj version_第5章-interas vpn_option C.mp4
11_MPLSVPN CSC-无ppt.mp4
12_MPLSVPN optionAB-无ppt.mp4
mpls -ppt
1.MPLS转发与LDP协议-yeslab上课版.pdf
10_L3 MPLS-VPN原理与应用-rj version_第5章-interas vpn.ppt
2_MPLS报文的转发的几个细节.pptx
3_LDP的收敛.pptx
4_advanced LDP feature.pptx
5.Introducing and Categorizing VPNs.pptx
6_L3 MPLS-VPN原理与应用-rj version_第1和2章.pdf
6_L3 MPLS-VPN原理与应用-rj version_第3章.pdf
7_L3 MPLS-VPN原理与应用-PE-CE之间的路由协议_第3章.ppt
8_troubleshooting Frame-Mode MPLS on Cisco IOS Platforms.pptx
9_0_Using Advanced VRF Import and Export Features.pptx
9_1_Introducing Overlapping VPNs.pptx
9_2_Introducing Central Services VPNs.pptx
9_3_Introducing Managed CE Router Service.pptx
mpls-部分
1_1mpls-1.mp4
3.LDP的收敛.mp4
视频版实验手册
YESLAB ccip mpls-vpn managed CE vpn.mp4
YESLAB ccip mpls-vpn managed CE vpn.txt
YESLAB ccip mpls-vpn pe-ce_ebgp.mp4
YESLAB ccip mpls-vpn pe-ce_ebgp.txt
YESLAB ccip mpls-vpn pe-ce_static rip.mp4
YESLAB ccip mpls-vpn pe-ce_static rip.txt
YESLAB ccip mpls-vpn-central service vpn.mp4
YESLAB ccip mpls-vpn-central service vpn.txt
YESLAB ccip mpls-vpn-CSC.mp4
YESLAB ccip mpls-vpn-CSC.txt
YESLAB ccip mpls-vpn-interas-option B.mp4
YESLAB ccip mpls-vpn-interas-option B.txt
YESLAB ccip mpls-vpn-interas-option C.mp4
YESLAB ccip mpls-vpn-interas-option C.txt
YESLAB ccip mpls-vpn-overlapping vpns.mp4
YESLAB ccip mpls-vpn-overlapping vpns.txt
YESLAB ccip mpls-vpn_pe-ce_static&rip.mp4
6.mplste
MPLS_TE概述_1.mp4
MPLS_TE基本配置_2.mp4
MPLS_TE信息发布_3_1.mp4
MPLS_TE信息发布_3_2.mp4
MPLS_TE路径计算_4.mp4
MPLS_TE路径建立_5.mp4
MPLS_TE流量转发_6.mp4
MPLS_TE流量的保护和恢复_7_1_路径保护.mp4
MPLS_TE流量的保护和恢复_7_2_FRR.mp4
MPLS_TE高级运用_8_1.mp4
MPLS_TE高级运用_8_2-MPLS TE和VPN的结合.mp4
mpls TE pdf version
MPLS_TE概述_1.pdf
MPLS_TE基本配置_2.pdf
MPLS_TE信息发布_3.pdf
MPLS_TE路径计算_4.pdf
MPLS_TE路径建立_5.pdf
MPLS_TE流量转发_6.pdf
MPLS_TE流量的保护和恢复_7.pdf
MPLS_TE高级运用_8.pdf
7.multicast
1_IP组播基础.mp4
2_IGMP协议原理_IGMPv1.mp4
2_IGMP协议原理_IGMPv2v3.mp4
3_组播路由协议PIM-DM.mp4
4_组播路由协议PIM-SM_实验部分.mp4
4_组播路由协议PIM-SM_理论部分.mp4
4_组播路由协议PIM-SM_详细图解.mp4
5_组播路由协议PIM双向树和SSM_birdir.mp4
5_组播路由协议PIM双向树和SSM_SSM部分.mp4
6_组播路由协议PIM-SM_RP.mp4
7_在LAN环境下限制组播流量.mp4
8_在NBMA环境下的组播.mp4
9_anycast RP.mp4
10_multicast VPN.mp4
11_IPv6_组播.mp4
ccip multicast yeslab pdf version
10_multicast VPN.pdf
11_IPv6_组播.pdf
1_IP组播基础.pdf
2_IGMP协议原理.pdf
3_组播路由协议PIM-DM.pdf
4_组播路由协议PIM-SM_理论部分.pdf
4_组播路由协议PIM-SM_详细图解.pdf
5_组播路由协议PIM双向树和SSM.pdf
6_组播路由协议PIM-SM_RP.pdf
7_在LAN环境下限制组播流量.pdf
8_在NBMA环境下的组播.pdf
9_anycast RP.pdf
8.qos
1_Understanding the Need for QoS.mp4
2_Implementing QoS.mp4
3_Identifying Models for Implementing QoS_1.mp4
3_Identifying Models for Implementing QoS_2.mp4
4_Understanding the Differentiated Services Model.mp4
5_Identifying QoS Mechanisms.mp4
6_Introducing Modular QoS CLI.mp4
7_Understanding Classification and Marking.mp4
8_Using MQC for Classification .mp4
9_Using MQC for Class-Based Marking.mp4
10_Using NBAR for Classification.mp4
11_Configuring QoS Preclassify.mp4
12_Configuring QoS Policy Propagation Through BGP.mp4
13_Introducing Queuing.mp4
14_Understanding Queuing Implementations.mp4
15_Configuring FIFO and WFQ.mp4
16_0_Configuring CBWFQ and LLQ.mp4
16_1_CBWFQ实验测试v2.mp4
16_2_LLQ测试实验v2.mp4
17_Introducing Congestion Avoidance and WRED.mp4
18_Configuring Class-Based Weighted RED.mp4
19-21_0_Understanding Traffic Policing and Shaping_policing部分.mp4
19-21_0_Understanding Traffic Policing and Shaping_shapping部分.mp4
19-21_1_police测试实验.mp4
19-21_2_shape测试实验.mp4
22_Configuring Class-Based Shaping on Frame Relay Interfaces.mp4
23_Understanding Link Efficiency Mechanisms.mp4
24_Configuring Link Fragmentation and Interleaving.mp4
25_1-交换机上qos之3750上的srr-入队列.mp4
25_2-交换机上qos之3750上的srr-出队列1.mp4
25_3-交换机上qos之3750上的srr-出队列2.mp4
25_4-SRR测试实验v2.mp4
25_5-交换机上qos之3750上的srr-实验讲解.mp4
26_yeslab version auto qos voip.mp4
26_交换机上的QOS之3550上的WRR测试实验v2-选修-无ppt.mp4
27_Introducing Cisco AutoQoS Enterprise.mp4
28_version auto qos voip.mp4
ppt
1_Understanding the Need for QoS.ppt
2_Implementing QoS.ppt
3_Identifying Models for Implementing QoS.ppt
4_Understanding the Differentiated Services Model.ppt
5_Identifying QoS Mechanisms.ppt
6_Introducing Modular QoS CLI.ppt
7_Understanding Classification and Marking.ppt
8_Using MQC for Classification .ppt
9_Using MQC for Class-Based Marking.ppt
10_Using NBAR for Classification.ppt
11_Configuring QoS Preclassify.ppt
12_Configuring QoS Policy Propagation Through BGP.ppt
13_Introducing Queuing.ppt
14_Understanding Queuing Implementations.ppt
15_Configuring FIFO and WFQ.ppt
16_Configuring CBWFQ and LLQ.ppt
17_Introducing Congestion Avoidance and WRED.ppt
18_Configuring Class-Based Weighted RED.ppt
19_Understanding Traffic Policing and Shaping.ppt
20_Configuring Class-Based Policing.ppt
21_Configuring Class-Based Shaping.ppt
22_Configuring Class-Based Shaping on Frame Relay Interfaces.ppt
23_Understanding Link Efficiency Mechanisms.ppt
24_Configuring Link Fragmentation and Interleaving.ppt
25_交换机QoS_SRR.pdf
27_yeslab version auto qos voip.pptx
28_Introducing Cisco AutoQoS Enterprise.ppt
QOS经典测试.pdf
wred统计信息.txt
发表于 2025-11-24 08:20:26 | 显示全部楼层
发表于 2025-11-24 10:01:49 | 显示全部楼层
发表于 2025-11-28 10:59:25 | 显示全部楼层
发表于 2025-11-29 19:18:18 | 显示全部楼层
发表于 2025-11-29 21:32:48 | 显示全部楼层
发表于 2025-12-3 15:46:35 | 显示全部楼层
发表于 2025-12-16 07:45:33 | 显示全部楼层
发表于 2026-1-15 07:15:12 | 显示全部楼层
发表于 2026-1-18 04:11:31 | 显示全部楼层
发表于 2026-1-19 13:36:52 | 显示全部楼层
发表于 2026-2-3 05:09:20 | 显示全部楼层
发表于 2026-3-6 14:34:40 | 显示全部楼层
发表于 2026-3-31 13:57:20 | 显示全部楼层
发表于 2026-4-18 12:59:20 | 显示全部楼层
发表于 2026-4-21 14:24:56 | 显示全部楼层
GMT+8, 2026-11-20 07:03
